A few weeks ago my power supply became unstable and had to be replaced. During that time it caused my GPU to start idling (405mhz mem and core - p8 state) while playing games, causing them to drop from 60-70fps down below 30fps. Now, my power supply has been replaced, but my GPU continues to throttle down after about 15 mins of playing any game. (up until the bad power supply, it ran my game without issues)
Specs:
Sony Vaio (SVF15A18CXB)
i7 3537u
12gb Ram
GeForce 735m 2GB
I have tried the following solutions to fix the issue
GPU-Z shows the perfcap as idle,
My temps are normal (60-70c)
I have used DDU to roll back drivers
clean installed the most current drivers
clean installed windows and the GPU itself
Used Nvidia Inspector and MSI AB to try and manually set the default clocks
I have set Nvidia control panel to all of the correct "prefer max performance" settings but the issue remains.
I have scoured google, and these forums for a solution for the past two weeks, and nothing seems to work. The only thing I can think of is that when the wonky power supply was connected it triggered something in the GPU to go into some kind of safe mode, and I can't find anything on how to check or fix that. Please help
Specs:
i7 3537u
12gb Ram
GeForce 735m 2GB
