Gpu keeps overheating
Storm_1
7
My computer was fine for the first 3 days and i think i may have messed something up and now my GPU sits at 54 Celsius on idle and as soon as i open up a game like cs go it jumps to 95 and monitors disconnect
Make sure the PC Case is in a well ventilated area.
Check to see if the intake and exhaust fan are working properly.
A picture inside of your PC case would be helpful.
yes that is my gpu cooler and it is pre built by ironside
you might want to email or call their customer support, what warranty do you have for that pc?
how can i fix that? and only started being this hot 2-3 days ago, ironside sending me a new fan to see if that will fix it
i contacted them and they think its a fan problem and i have full 5 year warranty
