Hi guys , well I noticed my gpu has some oil leakage all over it , and even going into the pcie port ,can the port be damaged this way , and what type of thermal pads should I change to , in order to prevent this from happening again
Funny(?) that you ask, because that's one of the places where it comes from. The oil is harmless.what type of thermal pads should I change to
before this post i didnt even know that thermal pads could sweat oil, apperntly they do when running gpu over 70c...well never had gpu running above 70c for too long, my old gtx 1070ti was running 80c first few days till i watercooled it to 50c, my new shiny rx 6800 runs up to 63c..so i should be still safeProbably oil from thermal pads.
Anyway - show photos.
(upload to imgur.com and post link)
They're comprised of the same materials. If it doesn't affect the gpu, it's not going to affect the mobo.Will my mb get damaged and if so how can I stop it from leaking .
It already is horizontal btw .They're comprised of the same materials. If it doesn't affect the gpu, it's not going to affect the mobo.
You don't stop it. A limited amount seeps out of the pads over time. For vertical gpu fans, put it back horizontally.
