Question GPU lights off max fan speed
iMatty
1,239
144
11,390
So as it is mentioned in the title, now a days once I try to power on my PC my GPU light would go off and fans would max speed.
Sometimes does CMOS clear a couple of times fixes the issue and the PC works fine even during load playing games etc.
But now a days, the issue is increasing more and more and am not really sure what the core issue is so I need help with this, I have a backup 2060 that I have in those cases so I can switch to it until I can save up for a new GPU in a month or two.
I can buy a 4060 but that's also a down grade from the 2080TI so am not sure.
my specs:
CPU: i7 12700k
Motherboard: MSI PRO Z790-P WIFI
Ram: G.Skill Trident Z5 RGB 32gb
Graphics Card: EVGA 2080TI Black edition gaming
Power Supply: EVGA Supernova G6 850w
Thank you in advance.
What BIOS version are you currently on your motherboard?
How old is your PSU?
Well bios version am not sure about it honestly, is there a way to check the bios version from inside without having to go to bios?
my PSU is around a year an half old that's it.
