Hi folks!
I need help. I'm swamped and have barely any time on my hands, so I can't troubleshoot as I use to. I thought someone here might bring light to what's wrong so I can optimize what to actually look for.
Here's the problem
When I play GPU-heavy games, they "crash". Depending on the game, it acts a bit differently. Games such as F1, Hots, Overwatch and COD: Warzone freeze up for one second and then the program just ends. I receive an error message that says roughly "Rendering device not found".
Some other games, as World of Warcraft and Rocket League, freeze up 5 seconds, disappears for 5 seconds and then reappears. It's like an uncontrolled timed force tab down.
My monitors don't turn off or lose signal, and I can immediately use software other than what crashed. These errors occur differently for each game, but roughly every 5 minutes.
When I stress-test my GPU, it doesn't crash.
Here's my setup and when it started to happen
Problems started when I got my G7 Odyssey. I used to run two monitors, the ASUS and the SyncMaster, but got the G7 and aimed for a triple setup. I realized quite quickly (but not right away) that some of the heaviest games crashed, such as F1 and Warzone. I then disconnected my ASUS and it was fine for some days.
View: https://imgur.com/dNrdp58
Here's the error message
Description
A problem with your hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
Code: 141
Parameter 1: ffffc204604b7050
Parameter 2: fffff803355d2298
Parameter 3: 0
Parameter 4: 2bf4
OS version: 10_0_18363
Service Pack: 0_0
Product: 256_1
OS Version: 10.0.18363.2.0.0.256.48
Locale ID: 8192
Description
The program Overwatch.exe version 1.54.0.10359 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: 2bf4
Start Time: 01d6ca563c05b704
Termination Time: 4294967295
Application Path: G:\Games\Overwatch\retail\Overwatch.exe
Report Id: 3a07db8f-c361-4cdf-a8e5-ac0a46e01962
Faulting package full name:
Faulting package-relative application ID:
Hang type: Top level window is idle
Here's what I've tested
I could have sworn this was an issue with my memory, but I can't find it.
Here's the problem
CPU | Intel i-7700K, used to be clocked to 4,35 GHz but now reset to 4,2 GHz |
GPU | EVGA GeForce GTX 1070 SC Gaming 8GB |
MB | MSI Z270 SLI Plus |
RAM | 2X Crucial Ballistix Sport LT Red DDR4 2400MHz 8GB (Total 16 GB) |
PSU | Corsair 500W |
Storage | 1TB M2 SSD, 2x 128 GB Sata SSDs and 500GB HDD |
Monitors | Samsung 27" G7 Odyssey (DisplayPort), ASUS 24" VG248QE (DVI, disconnected), Samsung 24" SyncMaster P2470HD (HDMI) |
Peripherals | Mouse, Keyboard, Headset |
Description
Problem signature
Code: 141
Parameter 3: 0
Parameter 4: 2bf4
Service Pack: 0_0
Product: 256_1
Locale ID: 8192
Description
Process ID: 2bf4
- MemTest on both RAM-sticks, no errors.
- Uninstalled and reinstalled graphic drivers and everything related to NVIDIA several times.
- Reset clock values.
- Updated BIOS.
- Made sure every power cable is thoroughly connected.
