GPU, motherboard and power supply compatibility.
GuidoSca
Commendable
Aug 21, 2016
6
Hello. I´ve just bought a prebuilt pc, wich has the following specs:
CPU:Intel i5 4460
Power Supply:500watts
8gb ram
Motherboard: Biostar H81MHV3 (Intel H81)
I was wondering if the Radeon RX 480, Radeon RX 460, Radeon RX 470, Radeon R9 380 or Nvidia GTX 960 would be suittable for my build, specially because of the motherboard and the power supply. Thank you for your time.
Actually, this will work will a graphics card. You can buy a molex to 8 pin converter on amazon and then plug that 8 pin into a gpu.
EDIT - Depending on the maker of the card and the card type you might either need a molex to a 6 pin or an 8 pin. For example, certain makers of the Rx 480 have 6 pin power connectors and others have 8 pin. If you decide on a card and a card maker you can look up a picture of it and see what power connector it requires.
GuidoSca
Commendable
Aug 21, 2016
6
I have not opened the case yet, but I googled the model and i found that it has the following:
Entry Line.
ATX format.
Connections: 24 pins, 3x4 pins, 2 SATA (20+4, 4 pins, 3x Molex, 2x SATA)
(Sorry that i voted down your awnser, I misstouched the button)
1Reshiram12
Commendable
Aug 7, 2016
105
GuidoSca
Commendable
Aug 21, 2016
6
Thank you man, you rock!
GuidoSca
Commendable
Aug 21, 2016
6
Of course! I think I´m going to stick with the GTX 960. What do you think?
