My wife's World of Warcraft keeps black screening and there's a sound loop as soon as the game loads into the world.
It happens on lowest settings, with the latest drivers, and the windows default vid drivers.
Previously the vid card would stop sending a signal altogether and it would say no signal to monitor.
My voltages looks okay, not too low
12V is 11.8
5V is 4.8
3.3V is 3.1
I've monitored temps and used furmark and cpu stress tests to replicate the problem
It ONLY happens if I start furmark and the cpu stress test at the same time... or load WoW
I've even swapped the graphics cards so I'm fairly certain it's a mobo or psu problem.
computer specs
http://speccy.piriform.com/results/3NJvVx6Lgv5JJ2xkBrMKNPj
OS Name Microsoft Windows 10 Pro
Version 10.0.17763 Build 17763
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name TASHA-PC
System Manufacturer To be filled by O.E.M.
System Model To be filled by O.E.M.
System Type x64-based PC
System SKU SKU
Processor AMD FX(tm)-8350 Eight-Core Processor, 4000 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 2103, 11/7/2013
SMBIOS Version 2.7
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Product M5A99X EVO R2.0
BaseBoard Version Rev 1.xx
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.17763.737"
User Name Tasha-PC\Tasha
Time Zone Mountain Daylight Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.9 GB
Available Physical Memory 12.4 GB
Total Virtual Memory 31.9 GB
Available Virtual Memory 28.0 GB
Page File Space 16.0 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not InstantGo, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
9/22/2019 4:12 PM Application Hang The program WinRAR.exe version 5.11.0.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
 Process ID: 2128
 Start Time: 01d571606991b988
 Termination Time: 561
 Application Path: C:\Program Files\WinRAR\WinRAR.exe
 Report Id: dd250793-3957-48ec-9dc8-e48900e35194
 Faulting package full name:
 Faulting package-relative application ID:
 Hang type: Unknown
9/23/2019 4:37 PM Application Hang The program ShellExperienceHost.exe version 10.0.17763.719 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
 Process ID: 26c0
 Start Time: 01d5722cd9592d10
 Termination Time: 4294967295
 Application Path: C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exe
 Report Id: 7b84535c-a579-4a68-b4fd-ca1f0c8329c9
 Faulting package full name: Microsoft.Windows.ShellExperienceHost_10.0.17763.1_neutral_neutral_cw5n1h2txyewy
 Faulting package-relative application ID: App
 Hang type: Quiesce
9/23/2019 4:48 PM Application Hang The program ShellExperienceHost.exe version 10.0.17763.719 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
 Process ID: 1fd0
 Start Time: 01d5722e709b495a
 Report Id: 91f9f93c-9f06-476f-a73c-831f0db92dcd
 Hang type: Quiesce
9/26/2019 2:11 PM Application Hang The program SecHealthUI.exe version 10.0.17763.652 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
 Process ID: 2cb4
 Start Time: 01d5747410044628
 Application Path: C:\Windows\SystemApps\Microsoft.Windows.SecHealthUI_cw5n1h2txyewy\SecHealthUI.exe
 Report Id: 68d41923-3144-48a5-8ca6-9fe0ea71ec82
 Faulting package full name: Microsoft.Windows.SecHealthUI_10.0.17763.1_neutral__cw5n1h2txyewy
 Faulting package-relative application ID: SecHealthUI
 Hang type: Cross-thread
9/26/2019 3:22 AM Application Error Faulting application name: TwitchUI.exe, version: 5.0.10.0, time stamp: 0x5d7abed7
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x6f430073
Faulting process id: 0x154c
Faulting application start time: 0x01d57418a25b2a83
Faulting application path: C:\Users\Tasha\AppData\Roaming\Curse Client\Bin\Electron\TwitchUI.exe
Faulting module path: unknown
Report Id: 264cc361-b309-4880-9b7f-a4d2af1d41a3
9/26/2019 3:26 PM Application Hang The program SearchUI.exe version 10.0.17763.719 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
 Process ID: 1430
 Start Time: 01d5747e587b4ad3
 Application Path: C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe
 Report Id: c5c3aa81-7e75-4439-a918-1415184f490b
 Faulting package full name: Microsoft.Windows.Cortana_1.11.6.17763_neutral_neutral_cw5n1h2txyewy
 Faulting package-relative application ID: CortanaUI
 Hang type: Quiesce
9/26/2019 3:42 AM Application Hang The program explorer.exe version 10.0.17763.719 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
 Process ID: 15dc
 Start Time: 01d5741c592304ff
 Termination Time: 20
 Application Path: C:\Windows\explorer.exe
 Report Id: 30e930af-ba0e-4935-a783-74772c220c01
 Hang type: Unknown
9/26/2019 3:51 AM Application Error Faulting application name: SearchUI.exe, version: 10.0.17763.719, time stamp: 0x5d524554
Faulting module name: ConstraintIndex.Search.dll, version: 10.0.17763.1, time stamp: 0x5b9c56e8
Fault offset: 0x000000000001a4aa
Faulting process id: 0x202c
Faulting application start time: 0x01d5741c8205bab4
Faulting application path: C:\WINDOWS\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe
Faulting module path: C:\Windows\System32\ConstraintIndex.Search.dll
Report Id: 4deae116-79f3-447a-9a04-447cd6848e43
12V is 11.8
5V is 4.8
3.3V is 3.1
computer specs
System SKU SKU
SMBIOS Version 2.7
BIOS Mode Legacy
 Process ID: 2128
 Hang type: Unknown
 Process ID: 26c0
 Hang type: Quiesce
 Process ID: 1fd0
 Hang type: Quiesce
 Process ID: 2cb4
 Process ID: 1430
 Hang type: Quiesce
 Process ID: 15dc
 Hang type: Unknown
