GPU overhating problem
Absolute_ZERO
I've recently noticed that my GPU temperature is around 50c at 0% load and jump to 70c as soon as i start playing games such as watchdogs at max specs. After playing for 15-20 minutes the temperature rises to 80c.
I'm using AMD R9 380 gpu with intel i5 6500 3.2 GHz cpu.
Should I be worried bout my gpu temp or it is normal for r9 380.
50 is actually about normal for that GPU, depending on the exact model of the card. Some GPUs won't even run their fans until they reach 50c. All it takes is configuring a custom fan profile to make the fans run at low RPM when the GPU reaches 30-40 or something like that and you'll see idle temps drop.
temp doest stay at 70 it rises to 80 within 15-20 min and dont u think 50 is too much for idle time
http://imgur.com/a/CAGLA
Is this setting ok ??
