So in past couple of weeks my PC started randomly restarting by itself while gaming, with no BSOD, screen just goes crazy for a second, I hear a loud noise from speakers and it restarts by itself with no BSOD dump, in Event Viewer it shows Kernel-Power 41, 63 error which basically means nothing to me, I searched on thousands of forums and applied all possible advices and "fixes", sadly with no success.
I've read that kernel 41 error can mean faulty PSU or overheating issue, as I have a relatively new 600W PSU I suspected on overheating
I then took a look at my temperatures and noticed 2 things (Click here to see the image):
1. The GPU temperature reaches over 70°C while under load (gaming)
2. The GPU fans is set to auto in crimson AMD driver software and it doesn't go above ~20% even though GPU is running hot in my opinion, so I tried turning the fans manually to a higher speeds and GPU started coolling down to ~59 meaning that fans can cool it but they don't do that automatically and I don't want to go to crimson every time I start and finish gaming to turn up and down fan speeds as I don't want them to run at 100% while idling.
I also dusted my PC so it's pretty clean and dust is not causing the overheating
Also my GPU never ran above ~50°C while gaming when I bought it.
I'm using MSI Gaming 270X 2GB OC Edition
The Random reboots may not have to do anything with overheating that is just what I suspect as I see no other possible cause at the moment
Any ideas on how to fix the GPU overheating issue?
All help would be much apprechiated
