Sorry for the limited and incorrect info in my post. What I meant to say was the gpu was overheating. I have sinced removed it and am using the onboard graphics and it is running fine except the Hmonitor still says the voltage is +2.67v on the 12v side. I guess the graphics card is bad.? Anyway here is the info from the Hmonitor.
Hmonitor Version 4.5.3.3 Pro F31337BB
(Trial)
H/W diagnostics info:
Windows XP Professional Version 5.1.2600 Service Pack 3
Manufacturer: MSI
Board model: ALBACORE
Version: 1.0
BIOS vendor: Phoenix Technologies, LTD
BIOS version: 3.20, Release date: 07/08/2005
Chipset: ATi RS480
Vendor ID: 2A20103C
SouthBridge: 43721002
SMB port used: 0400
CPU:AMD Athlon(tm) 64 Processor 3500+
CPUId:0-F-F-2
Cores:1
Internal Freq=1791.0 MHz
External Freq=162.82 MHz
Multiplier=11.0
SystemBus Freq=2000.0 MHz DDR
Memory Freq=200.0 MHz DDR
Thermo control configuration:
Full Throttle:100.0%
AMD Low Power mode😀isabled
Device:None Throttle:25.0% Enable at:70.0°C Disable at:65.0°C
Main Sensor: LPC47M192
Poll intervals: Sensors=5 sec, HDDs=5 min, Warnings=5 sec
EventLog: Disabled, C:\Program Files\Hmonitor\EventLog.txt
DataLog: Disabled, C:\Program
Loginterval=1 min, LogRotation=Never
Monitored data values:
Mainboard=39.0°C (5,Auto,0.0°C)
CPU1=31.0°C (1,Auto,0.0°C)
CPU2=xx.x°C (0,Auto,0.0°C)
CPU0 Core=35.0°C (0,AMDCore,0.0°C)
Chassis=1198 rpm
CPU1=1638 rpm
CPU2=xxxx rpm
Power=xxxx rpm
Core=+x.xxV
Aux=+x.xxV
+3.3V=+x.xxV
+5V=+x.xxV
+12V=+2.67V
-12V=-xx.xxV
-5V=-x.xxV
HDD1 temp=43.0°C ST3250823AS 3.03 ATA
Theis was with the graphics card removed. The card was an HIS but don't remember the number.
