[SOLVED] GPU Power cables
Aug 31, 2019
12
Hello,
today i have bought this gpu, i can use one cable with two connectors 6+2 pin or i need to use two cable? My psu is a Corsair CS650M. Also, probably its to late to ask but the Radeon 5700xt is better or have the same performance of RTX 2060 Super?
Reactions: Dope Senpai
Aug 31, 2019
12
You can use a single PCIe cable (with both connectors attached to the GPU).
The Radeon is stronger that the 2060 in many comparisons. Both perform well.
See here: https://www.tomshardware.com/reviews/amd-radeon-rx_5700-rx_5700_xt,6216-2.html
Hello, thanks for the help. I have another question, i have deleted the order of RTX 2060 Super and with more 60€ i have bought a RTX 2070 Super Founders Edition from the NVIDIA Store. Even in this case i can use a single PCIe cable?
