GPU Power limit 100% limitation
madmatt9797
11
So in msi afterburner i've set the power limit to 114%, but kombustor is only showing it's going up to 100%. how can i fix this limitation?
I have the MSI GTX 660 ti
No, the power limit. it's not voltage anyone should be able to do it as far as i know regardless of the bios. it's done in MSI Afterburner, all the tutorials i've seen say crank up the power limit to max, which mine is only 114%, and it's not even showing it's active at 114% in my benchmarking softwares
look in the top right of this pic at the power TPD
]http://i.imgur.com/VL8SQs0.jpg
http://i.imgur.com/zb7TMxI.jpg
i'm not trying to unlock voltage though, take a look
Will try and respond if it works or not in a few hours
Still doesn't work.. exact same problem even after updating
Latest posts
