Hi all. I have r9 390 that i wanna try out and probably use for some time on my PC untill i get money for better(more efficient) GPU or/and better PSU.
I use CM G550M psu with i7 6700 (non k) with 2 fans and 4 drives powered from modular molex and sata power cables. The PSU originally has only 1 fixed PCIE cable with 8pin + another 8 pin (extended) from it. But two years ago, for some reason i have cut that second 8 pin cable that came out from first 8 pin. Dont ask me why, please. Since it i used few cards, so 8 pin out i didnt cut works fine. But now i want to plug in an GPU that needs 8+6 pin (r9 390), which i dont have since i was stupid enough to cut off one of those power pins.
Now my idea is to:
Please dont:
Now my idea is to:
- Use card only with 1x8 pin - which i guess it would work, but not to the potential of that card since it couldnt draw enough power.
- Use molex / sata power cables adapted to 6 pin gpu power. - Which im thinking are suitable to cover for 75W 6pin cable
- Use 5 pin out on my psu thats ment for molex / sata modular power cables and get it to 6pin. - I have seen online some similar cables for modular psus that go to 6 pin pcie, tho i cant find anything similar for sale. But since they are built for molex / sata power cables ment for drives and fans, then i guess it would be the same as adapting from molex / sata to 6 pin, right? What if i used 2 of those 5 pin outs with modular cables that came with my psu, and get 1 molex or sata out from each of those cable to go to 1 6pin and to gpu. I saw many 6 pin adapters that go from 2 molexes instead of just one.
Please dont:
- Strive away from topic and what info i am trying to get so you would tell me how i need to change psu, gpu, pc or whatever. I came for tech tips and talk to try and see if anything can be managed here and whats the best way of doing it - if doing it. If i were in position to buy new adequate psu for 300W card, i would gladly invest that money in gpu that is of same or better performance while it spends less power and needs less pcie cables.
- Tell me how 550w isnt enough ,since a personal friend of mine used safely fx 6300 (95W) and r9 290 on similar 500w psu for 2 years until he sold it, at which point it was also working.
