S slacker117 Dec 30, 2018 1 0 10 Dec 30, 2018 #1 So I just upgraded to the Asus ROG gtx 1070 which only uses 1 8 pin power connector, is it okay to use a cable that has 2 8 pin connectors on it and only use 1 8 pin? Or should I go out and buy a single 8 pin cable?
Supahos Expert Ambassador Nov 11, 2013 12,755 48 57,640 Dec 30, 2018 Solution #2 Use the one you have. No issues Upvote 0 Downvote Solution
