GPU Power Supply
Ethan Carlone
56
So, my friend wants to add a r7 250x to his Dell Inspirion PC. The PC has a 300w psu which checks out with the 250x. The problem is that the psu doesn't provide a six pin connector. Is there any way to make this work? Thank you for the feedback.
there are dual molex to six pin adapters on the market, but really, if a PSU does not have the connectors you want, it probably was never meant to power the item you want to power. while it should work, it will tax that power supply, the results could end badly in the long run.
adapters are not recommended when the psu is so weak
you would be much better off with a gtx 750 ti, there are versions that do not need a pcie 6-pin cable
it's much faster too
