[SOLVED] Gpu problem I think
Nov 28, 2019
6
When I start my pc I get the usual mobo stuff but then After the windows circle spins It just goes black. The only thing I changed before it was my gpu fan had a broken blade and i changed it with one from amazon and it didn’t work (just got REALLY hot and smelled like it was burning) then my I screwed my gpu all back together and it started doing that.
CPU intel i5 6400
GPU GTX 750TI
RAM 8 gbs
Well i dont realy understand what is the question here.
Try running windows in safe mode and see will it work if it works install DDU and uninstall all display drivers and after that turn your pc normaly and install the latest drivers for that gpu.
