Gpu problem need help!!
Flinter_cs
Hey i wonder if these to work together in a sli :)?
ASUS GeForce® BLACK GTX 970 4GB GDDR5
GPU : GeForce GTX 970, 1644 cores, 28nm
GPU Clockspeed : 1253 MHz (boost) / 1114 MHz (base)
Memory : 4096MB GDDR5 (256 bit)
Memory Clockspeed : 7.0 Gbps
Bandwidth : 224 GB/s
Bus : PCI-Express 3.0
Video-Features : HDMI 2.0
Cooling : 2-Slot Cooling
Connectivity : DL-DVI-I, HDMI 2.0, 3xDisplayPort 1.2
Product Size : x 290mm(L) 147mm(W)
Power Connector : 1x8-pin + 1x6-pin
Power Consumption ; 146 W
ASUS GeForce® STRIX GTX 970 4GB GDDR5
Connectivity : DL-DVI-I, DL-DVI-D, HDMI 2.0, DisplayPort 1.2
Product Size : x 288.6mm(L) 134.4 mm(W)
Power Connector : 8-pin
If you want to sli, it has to be the exact same card/model
You could sell your asus black and get another strix for sli
no it doesn't need to be the same make or model, as long as the gpu is the same type e.g. gtx 970
they will sli
