Absolutely do *not* open up a second thread for the same problem.
My PC won't boot up if GPU is installed and it beeps in POST with 4-2-3-3 pattern apparently it's an extended block move problem, what does it mean? It turns on if GPU is not installed and only using integrated graphics. I did every troubleshooting I could and i narrowed it down to either motherboard problem or GPU problem.
I tried:
re seating everything
swapping psu
clearing cmos
I havent tried swapping GPU or using another GPU on my pc cause I dont have spares
can you please help me?
SPECS:
mb: NEC ms9666 012
PSU: inplay GS250BK ( I already swapped with other ones and it works so its not the problem)
GPU: AMD radeon 7850 HD
CPU intel core i3 540
other components are working fine because I already checked them. Help me please
I tried:
swapping psu
clearing cmos
SPECS:
mb: NEC ms9666 012
