Question GPU problem?
xiiininja
98
this is my specs
i3-7100
mortar b250m
3x 4 GB RAM
RX570 sapphire 4gb+ nitro
PSU corsair 450w
when i running game like League of legends theres no problem
when i run PUBG i got pixel problem.
how to fix? some other said PSU problem need a 600w
stick with 1 thread, don't spam, don't bump
this is my specs
i3-7100
mortar b250m
3x 4 GB RAM
PSU corsair 450w
Might be psu, might be damaged card, might be overheating, might be all of them. Who knows?
  • Make sure card is properly connected to PSU
  • clean CPU/GPU from dust, if You have to
  • Check on steam, if some game files are missing
  • reinstall GPU drivers
  • check temperatures on GPU/CPU
  • download and run furmark to check for artifacts on load
when i run 1050 ti all run good
should i connect both 6 and 8 pin? if yes i already did but it same
this is the result i dont see problem
If every benchmark, other games etc runs perfectly fine, and You have no issues, probably it's something with the software.
  • Check temperatures on GPU once again, under full load, for about 1-2 h
  • try to reinstall pubg
  • try to use another, older drivers
If it doesn't work, then i'm out of ideas (assuming, that the card itself is good and You checked on that)
Latest posts
