[SOLVED] GPU problem
iMatty
1,224
142
11,390
So I just installed a new gpu and I tried installing the new drivers, I used the DDU and uninstalled the old drivers pc was so slow until i did that then it went back to normal.
The problem is that whenever i tried to install the new drivers through NVidia expernice or even manual driver download it said that this version of windows is not compitable.
The old one was an OEM 1050ti and the new gpu os 2060rtx
D
Are you having a prebuilt OEM system ? Just make sure you are installing the GAME ready drivers/GRD, and not the Creator version/CRD. Also, there are 2 driver types, DCH and Standard. Which one did you install ?
By the way, DCH drivers cannot be installed over Standard Drivers, and Standard Drivers cannot be installed over DCH Drivers. The choice must be made after a cleaning via DDU.
To check which display driver type you need, right-click over the Windows desktop -> select NVIDIA Control Panel -> click on the System Information link on the bottom left hand corner of the NVIDIA Control Panel -> look at text that follows “Driver Type”. You should see one of the following : DCH or Standard, assuming you are able to...
To check which display driver type you need, right-click over the Windows desktop -> select NVIDIA Control Panel -> click on the System Information link on the bottom left hand corner of the NVIDIA Control Panel -> look at text that follows “Driver Type”. You should see one of the following : DCH or Standard, assuming you are able to install the drivers.
EDIT: Just make sure you are installing the correct driver version as well, i.e 64-bit if using a 64-bit OS, and not 32-bit.
Reactions: lux1109 and iMatty
