Hello,
My build is as follows: Asrock Pro3 R2.0 motherboard, Amd Fx-4300 cpu, Gtx 960 gpu, 111 gb adata sp 550 SSD, 1 tb seagate sd1000dm HDD and 8 gb dual channel ddr3 running at 1600 mhz.
I had problems since the beginning. While playing games and watching videos I could notice delays/stuttering which didn't affect sound but were very annoying. These problems would only be present at the next start after using shutting down option(not after sleep). However I found a fix; if I would restart the pc the stuttering would go away and everything would work perfectly. But not even restart would fix it every time. If everything worked perfectly and I would restart a second time the vid delays/stuttering would be back again. So it works only every second restart.
Recently I decided to upgrade to windows 10 since I've had 7 for quite a while but the problems seem to be even more pronounced in windows 10.
When I start the pc (after shut down, not sleep) I get the "display driver failed to start" notification and the screen goes black every couple of seconds. Sometimes it's so bad I can barely restart it, but once I do everything works perfectly!
Putting pc in sleep mode and waking it seems to work fine but the problem is that the fans keep spinning and it makes a loud noise.
What I tried and didn't work:
1. Reinstalled windows couple of times (only on ssd). Sometimes I would let windows update install the gpu driver, other times I would do it manually from Geforce website.
2. Updated. uninstalled and reinstalled gpu driver from device manager. Running on microsoft basic display adapter seemed ok but I can't do anything with it.
3. Updated UEFI
4. Disabled fast start up from bios and win 10 since I thought that something might not be loading properly but since it does that every second restart too I had to know it wouldn't work.
I'm not sure what to do next.
Any possible fixes you guys might have in mind it would be greatly appreciated !!
I'm sorry I posted in the wrong section at first, the thread from components can be removed.
3. Updated UEFI
