GPU Problems need help fast
Swatting
114
So i took out my GPU and it sounded like plastic snapped and fell within the motherboard, within further in speculation there seems to be no visual problems, so i put my card in, but there is lines within the thing im watching, for exaple, say i was watching you tube, the vid looks horrible (at high settings) and its like there been a knife and there is line slike the video isnt correcty loaded, everything looks horrible.
GPU: XFX 7770 GHz edition
( i had this problem with my old pc aswell after taking out the gpu)
Thanks
There's a small locking clip at the back of the GPU where it slides into the PCI-E slot, check the card and the rear of the slot, if it broke off the card may not be fully seated (happens quite often really)
can you show me a picture please?
