Gpu Running Around 7x Slower Than It should be
May 7, 2018
4
Im currently using a GT 1030 due to lack of money to spend on a graohic card, Ive been using the ASUS GT 1030 OC Edition One Now Since March(2 Months) After Using DDU Yeasterday to uninstall my previous graphic drivers I then reinstalled the latest ones for my gt 1030, Howevee now when idke the memory clock is at 800mhz when should be 6000 and gpu clock at 139 when should be around 1200, This is idle btw but before the reinstallation i was getting a much higher speeds than now...
Getting max clock speeds at idle actually is incorrect, so the idle state is correct now.
The FPS difference in game could be any number of things, hardware or driver related. If you are getting the same speeds as you did before, and the same settings in game, its probably something the new driver did.
They are called 2D-mode and 3D mode. For 2D it's enough to have that low frequency, whereas 3D needs high frequency.
I assume that it was a bug or something back there, and now after DDU's work it shows the values properly. However, make sure it shows a high frequency while running some game or a benchmark. If it does, then everything is fine.
They are what they should be 6000mhz memory and gpu clock at 1200 mhz but im getting around 20 fps less in csgo and I used to get and it used to be at them speeds while idle, Sorry if im making myself sound super dumb here aha
