GPU running at insane temps.
Most GPUs run a load at 75c. If you have sli, make that 80-85c. They throttle in self preservation around 90c-100c. If you are concerned you can increase the number of fans in your case, but my 770s typically run around 40c at idle during the summer.
Also, is that 40c while using graphics intense applications or idle?
