[SOLVED] GPU sag in an angled case
Jan 26, 2020
Just ordered all the parts for a new build.
My only concern is gpu sag at this point.
The case is an Antec Torque so the motherboard and anything attached to it will be sitting at an angle. The angle puts the corner of the card that usually sags in a position that presumably will make it worse.
Due to the angle I am wondering if any of the currently available support options would be effective in this application.
Edit:
Motherboard is the MSI x570 godlike,
GPU is EVGA GeForce RTX 2080 Ti FTW3 ULTRA Gaming 11GB
Any help would be greatly appreciated!
I was actually looking at that exact brace.
What im wondering is if the brace will be as effective with everything at a slant instead of being horizontal like in most cases.
As cheap as the braces are though I will definitely get one, better safe than sorry!
Thanks for the reply, I appreciate you taking the time to answer.
