Question GPU sagging and question about material used in products to help with that.
Nereknu
38
Hello I bought the palit jetstream 2070 super GPU and after I ordered it I found out it weights 1,8kg !! It's a lot + my CPU cooler weights about 1kg so I am very scared about my motherboard can it hurt them? Should I order smaller CPU cooler or the cpu cooler won't do anything and I should be concerned about the GPU? My mobo is b450 tomahawk max and my case fractal design meshify s2.
I did a little bit of research and ordered this thing to help with support of the GPU so it won't sag but maybe the PCI ones are better?
https://www.aliexpress.com/item/33062103294.html?spm=a2g0s.9042311.0.0.72354c4dLD5AKx
My concern is about the material I am not an expert and I don't know how it works but I am scared if it can't "kill" my GPU because it's bad material I heard something about Aluminum Alloy beingan electrical conductor? I would buy from amazon but there is a big shipping for my country it cost more than the product itself...I can buy something like this which is different maybe better material but I don't think if this material can hold this heavy GPU
https://www.aliexpress.com/item/32858849594.html?spm=a2g0o.productlist.0.0.1b1d4288TqtG7V&algo_pvid=04e6b90d-5b25-456c-be65-da0c91e9bcf3&algo_expid=04e6b90d-5b25-456c-be65-da0c91e9bcf3-0&btsid=79699d5c-ec6b-4d0b-bde7-3d43765574c3&ws_ab_test=searchweb0_0,searchweb201602_10,searchweb201603_52
or
https://www.aliexpress.com/item/32971719465.html?spm=a2g0o.productlist.0.0.1b1d4288TqtG7V&algo_pvid=47a29c8d-482b-4112-8c68-3073157fa797&algo_expid=47a29c8d-482b-4112-8c68-3073157fa797-0&btsid=f0cd3c5d-bf18-48bb-9684-959e0f41b53f&ws_ab_test=searchweb0_0,searchweb201602_10,searchweb201603_52
Any tips and help is appreciated.
stefanos50
479
120
490
52
GPU PCB's are stress tested and designed to flex so sagging wont damage your gpu. I read there is a small percentage that it can damage your motherboard pcie slot but especially with the silver ones like the B450 Tomahawk have it wont happen. I personally use this with my Palit 2080 https://www.coolermaster.com/catalog/cases/accessories/universal-graphics-card-holder-2-supports/ and it has strong magnets and even you move your case arround it wont move at all. I also tried something like your first option and it was not that good.
Nereknu
38
yes I know I need it for myself so I feel "better" the GPU is safer..
I was just curious if the first I ordered will do okay I am mostly concerned about the material it's made of like I am imagining the gpu will do some electricity and the holder can do something bad and kill my GPU but probably I am just silly but I was saving a lot for my new PC and I don't want to lose it because of stupid mistake...
stefanos50
479
120
490
52
It will be under the plastic under the card to hold it (where the fans are) i dont get how there is any way it can interact with electrical components of the card.
Nereknu
38
I don't know how electricity works sorry I was thinking maybe it's going around the GPU and might run into the holder etc and maybe then it might short circuit
