Gpu selection help
tasos123456789
5
I have a 1920x1080 monitor and i want to choose an r9 290 OR r9 290x gpu/
1st. Its better to buy 290x or the difference of perfomrnace is litlle and the money is waste?
2ond.I am bettween (powercolor PCS+ ) ,(saphire vapor-x tri-x oc), (xfx black oc edition) ,, (gigabyte oc windforce 3x) ...I want 1000+Mhz clock and 5Ghz++ memory..Help...
well the cheapestr9290x is at least 400 something euros isnt it? I remember looking into an r9 290x aswell, but I changed my mind when the gtx 970 came out
GTX 970 4GB VRAM - MSI , Asus or EVGA
if I may offer you some other advise. either wait for the new AMD series, or get a card from the new nvidia series that laucnhed last week.
a gtx 970 has a better performance then the r9 290x and it's cheaper, gets less hot and uses less power.
well i dont care really for the heatsink i can get watercool ......but amd r9 290x has 512 bit bus and 970 256 bit//............its the double also and r9 290x has 428 euro and gtx 970 strix 400 is not a big diference ...
well i leave in Greece and on the cheapest site has 359 euro=455 dollars
Well i think that 970 is better cause in future i can go sli cheaper thanks a lot
