GPU/Sound card line noise at 144hz
vinnie12345
5
asus z170 mk1
asus strix sound card
6600k
32gb g.skill 2132
evga hybrid gtx 1080
samsung evo 840
I am getting buzzing sounds that are loudest when playing games. From what i can tell this is line noise caused by the fps being produced from my gpu.
When i limit the fps to 60 the noise is gone.
From 63-144hz the noise increases in pitch.
Anything above 144hz and the noise is the same.
Turning the volume up and down does nothing to the volume of the noise. The buzzing is the same from full mute to 100% volume.
I would not suspect line noise to be an issue with an internal sound card and suspect a hardware issue in the sound card itself or possibly in the mobo, but I would really appreciate some advice. I have also been experiencing game crashes that would require me to hard shutdown, but I have learned to set task manager to "always on top".
