Gpu sound problem
ritchyboy
27
I recently change my gpu fan since the temp was high and my computer would shut down when i was playing now I dont have this problem anymore.But since then i have a sound bug that i can only hear from my headset when listen music and having a stream open without checking it at the moment.I also notice that my activity get high % when it happening sometime like this: http://puu.sh/cn4tu/f32603f335.jpg(also not like in the picture my gpu clock goes to 1000mhz like when I'm playing game).When I first brough my gpu in 2012(my Pc is Born) i was always at 0 activity.that when I' m doing almost nothing http://puu.sh/cn5Ih/83b8f840a9.jpg
Also I used to play on 150 fps I notice a drop if it linked?I dont know if it related but i have freeze fps for a duration of 1seconde sometime.
Here my Spec:
Gpu: XFX Double D FX-787A-CDFC Radeon HD 7870 GHz Edition 2GB
Cpu AMD FX-8150 Zambezi 8-Core 3.6GHz Socket
PS: FirePower Fatal1ty 750W
Motherboard: GIGABYTE GA-970A-D3
Ram: 1x G.SKILL Ripjaws X Series 8GB
Thank for your care
Yes possibly, what other anti-virus software are you running?
Another possibility could be...
When you gpu activity is high at the low clock rates, it is often ads or flash content on the page which can trigger your gpu into action, it is completely normal.
The sound you can hear, if it's coming from your headset and not your gpu it is probably software related or your headset. Also with the freezes try defragging your hdd, check it's health and make sure it meets everything. Another reason it could freeze is because of malware or viruses.
Try a program called Malwarebytes.
-good luck
Could it be that the cause of my freeze frame issue(for the sound i will check my headset right after) http://puu.sh/coqPu/df9c9d7dc2.jpg
Another possibility could be that you have other programs which could be slowing down your pc too.
I'm just running avast as an anti-virus,also I just finish my fragmentation like you ask me too(I will see the result so far)
