I have a Sapphire dual-x R9 270x card. Never had any problems with it.
When I got on the computer this morning ( it stayed on all night) everything seemed fine but after 5-10 sec the card stopped working. The screen displayed small grey bars (not artifacts, just a wall of grey).
Now, when the computer turns on, the gpu fans are working but i get no signal.
I tried removing all the dust and re-seating it but it didn't work.
Everything works fine with an older gpu I put in.
Any tips on how to fix it?
I've also been looking for a replacement but I'm not up to date with gpus. A friend recommended the Gigabyte gtx 1060 6gb. How does that compare to the one I had?
Thanks.
Thanks.
