Gpu stuck at low speeds
Your memory clock will display at half its true speed, thats normal, so dont worry about that, but your GPU clock should be higher. Does it rise when stressing the GPU? When idle it will stay low.
Have you overclocked it at all? If you get a failed GPU OC it'll lock at a low clock until you reboot your system?
It does not rise when i do anything that requires more power. I have not overclocked it so that is not the problem
