I have built up a new PC,
MB: Asus Z270a
CPU: G4400
Ram: 4G Kingstone
HDD: 360GB
Power: 430W
GPU: 2X MSI 1060GTX
I want to use it for mining,
after starting up windows 10, all system is working fine, graphic cards are detected.
If mining is started, after a while one of the GPU's suddenly stops working! its fan start to spin at 100% speed, and if I scan for hardware change, the faulty GPU will be removed from the list. It should be mentioned, the GPU temperature is monitored and is about 65c all the time. the other GPU keeps working fine.
restarting the PC will solve the problem, however the fault will occur again if mining starts.
Is it related to my power supply? any other idea?!
MB: Asus Z270a
CPU: G4400
Ram: 4G Kingstone
HDD: 360GB
Power: 430W
GPU: 2X MSI 1060GTX
