Gpu temperature issue
Feb 1, 2019
i have msi gaming x rx 580 gpu when i play highest game so my gpu becoming 85 temperature when i do gpu scaling low then my gpu showing 45 to 50c so its bottleneck issu or its gpu is sick im using this gpu on core i3 6100
I consider 85C about the limit for GPUs.....so I'm really not convinced you have a problem. I'd like to see 80C or less though. Maybe try running with your case open and see if you see improvement. If you do, maybe consider adding some case fans.
I don't think you are looking at much of a bottleneck issue.
Not sure what a possible bottleneck has to do with GPU temps.
85 C is pretty warm, but not really dangerous. If you want to lower it you can try increasing the fan speed. I'd also look into undervolting the GPU, which is a great way to lower temps and/or fan noise on RX 580s.
Latest posts
