I have a Zotac 1080ti. Recently I've played lots of Call of Duty: Warzone, and had various crashes and errors, most of which are probably not due to my hardware (which is usually stable). But some of them might be a result of the game pushing my hardware limits. To that end, I'm trying to eliminate variables.
I installed a piece of Zotac software called Firestorm which lets me kick the GPU fan up to 100% when temp exceeds, say, 50 or 60 C. It works, but I have to manually approve it via UAC every time I reboot, and then manually select the desired profile. (It has the option to auto launch and apply previous settings on boot - but even though the icon appears, it doesn't actually work unless I go in and click on "Apply" every time.)
Questions:
1. What is a reasonable temp at which GPU fans should run at 100% speed? (If it's high enough, maybe I don't need to mess with fan speeds at all.)
2. Assuming that I should increase GPU fan speeds, is there a way to adjust my fan speed curve in BIOS or firmware?
3. Finally, assuming that the only way I can tinker with GPU fan speeds is software, is there a better software solution?
Thanks!
Questions:
Thanks!
