Hi guys,
I've been having a problem that's been bothering me for a long time, and I don't know if this is normal behavior from the graphics card or if something is wrong.
My graphics card's temperature usually ranges from 50 to 55 degrees Celsius when idle and under light use, given that I live in Egypt and the temperatures here are quite high.
The problem specifically appears as soon as I start playing some games. The temperature suddenly rises to 80 degrees Celsius for a few moments before the fans kick in. The temperature then drops to 75, then 70, then 65 degrees Celsius, and the fan speeds also drop, but everything is fine.
My question is, is this normal behavior for most graphics cards, or is there a problem with my card?
My system specs are as follows:
GPU: ASUS DUAL RTX 4070
CPU: Core I5-11400
Mobo: ASUS ROG Strix B560 G-Gaming WiFi
Case: Cooler Master MasterCase H500 Mid-Tower Case {Opened Case}
PSU: Antec New Eco 850W Gold
I just want to know if all NVIDIA cards behave this way, given that I've owned an AMD card in the past and never noticed this problem.
CPU: Core I5-11400
