GPU that works on 280W Fujitsu OEM power supply
No.
Here is a handy chart that spells out what psu you need for various graphics cards.
http://www.realhardtechx.com/index_archivos/Page362.htm
Assuming your psu is a standard ATX psu you should be able to replace it with a stronger psu.
Measure the dimensions of your current psu and compare it to a candidate replacement.
If your pc is in a small form factor case, you may need a more compact psu or graphics card.
Will RX 460 or GTX 1050 work?
can i replace the PSU?
No.
Thanks for answer guys but i built myself a PC with GTX 1060 6GB instead , thanks tho
