Hi community,
Why Are You Upgrading: I want to upgrade my GPU because my current GPU is starting to make an unreasonable amount of noise and the fan is acting up. It sounds like rattling and is caused by vibrations in the plastic around the card. Have taken it apart, there are no loose parts, and while I might be able to replace the fan to fix the problem, I am 99% sure that the fan acting up has caused temperatures go close to or above 100 C. I am mostly curious whether (i) the rest of my build still warrants an upgrade and (ii) the upgrade I have in mind (GTX 1060) is a good fit for the rest of the build. I am of course open to any suggestions.
Current build:
Approximate Purchase Date: Within the next month
Budget Range: EUR 150-300
System Usage: Gaming, browsing websites, casting movies to chromecast
Parts Preferences: GTX 1060 or RX 580 (leaning towards the former as RX 580 showed many issue threads here)
Preferred Website(s) for Parts: Local or European vendors
Overclocking: No
Your Monitor Resolution: 1920x1080
Thanks in advance!
Thornum
Current build:
Motherboard: Asus P8Z77-V LE Plus
CPU: Intel Core i5-3350P 3.10 GHz Quad Core
CPU cooler: Cooler Master Hyper 412S
GPU: Sapphire Radeon HD 7950 3072 MB (to be replaced)
PSU: OCZ ZT Series ZT650W, 20+24 Pins
RAM: 2x Corsair XMS3 8 GB, PC3-12800, 1600 MHz
Tower: Corsair Carbide Series 300R
SSD: OCZ Vertex 4 128 GB, S-ATA III
HDD: WD Caviar Green WD10EZRX 1 TB
OS: Windows 10
Overclocking: No
Thanks in advance!
Thornum
