Hi,
I recently upgraded my GPU for my sons pc.
Recently I had changed this pc to an ultra wide monitor setup 3440*1440 *120hz and the 1080ti I had in there was struggling a bit on some games. It had been doing ok, but then I noticed the frames dropping heavily on occasions (might be linked to current issue)
So I got a used 2080ti for a good price, don't fancy waiting for new 3 series for now.
Install of card was fine, I did a fresh install of Windows etc as the performance was not as expected, despite removing old drivers, ddu etc.
The performance is poor, less performance than I was getting with my 1080ti.
I am wondering if my PSU is faulty. Is a Corsair 750x, about 18 months old. I have 32gb of DDR 4 3000 ram and a ryzen 2600 cpu.
When I run 3d Mark with the OSD from afterburner on, putting the power at 112 % and look at the power number, it will start the benchmark at the 112% for maybe 1 second or 2 and then drop down to a max of 70% for the remainder of the test.
Does this point to a PSU issue. The card appears to be operating fine, does not go above 65 degrees under load and all seems well on that front.
Appreciate any help please.
Thanks
Update: Fixed, card is faulty.
Thanks
