Question GPU vanished after Windows updateds - Razer Blade 15 2018 Advanced
Oct 29, 2020
I have had this laptop for about 2 years, and since I first got it, it has been fine, but something stranged has happened this week.
So 2 days I go I updated Windows before switching off my Blade, then the following day I noticed the GPU had stopped showing it's temperature on the task bar. I went to investigate and found that the GPU had gone from the Device manager. I tried uninstalling drivers and installing the latest one, but it didn't help.
So I used the Razer recovery option to start a fresh install and the GPU is still not appearing in the Device manager, even if I press show hidden. So, should I presume the GPU has failed?
If I try to install the Geforce drivers I just get this error
The model is an i7 8750H CPU and GTX 1070 Max-Q GPU.
