M Mahiyan Rahman Commendable May 25, 2017 52 0 1,660 May 25, 2017 #1 My gpu voltage is showing invalid results like 188665836mv. what does it mean? what sort of problem is this? an why is it happening. need suggestion. TIA
Solution Makentox May 25, 2017 Download MSI afterburner, edit settings to show voltage, it should show correctly.
Makentox Distinguished Sep 24, 2016 1,099 0 20,510 May 25, 2017 #2 What software do you use? What is your gpu? Nobody will help you based on 0 info. Most likely your software read failure voltage. Upvote 0 Downvote
M Mahiyan Rahman Commendable May 25, 2017 52 0 1,660 May 25, 2017 #3 Makentox : What software do you use? What is your gpu? Nobody will help you based on 0 info. Most likely your software read failure voltage. Upvote 0 Downvote
M Mahiyan Rahman Commendable May 25, 2017 52 0 1,660 May 25, 2017 #4 I use Sapphire R7 260x 2gb and the software I use is Logitech ARX control Upvote 0 Downvote
Makentox Distinguished Sep 24, 2016 1,099 0 20,510 May 25, 2017 Solution #5 Download MSI afterburner, edit settings to show voltage, it should show correctly. Upvote 0 Downvote Solution
