GPU water cooling compatibility
Presidium
28
Hello,
I am new to water cooling, so I figured I'd cheat and get one of these cool new all-in-one CPU/GPU coolers from ID-Cooling, the Hunter Duet (http://www.idcooling.com/Product/detail/id/56/name/HUNTER%20DUET). It is compatible with my CPU, but I'm not sure how to determine compatibility for my GPU. Note, this is a new rig, so which card I buy is still kind of up in the air, but I was leaning toward an NVIDIA GTX 960.
The measurements for GPU compatibility with the water cooling are 58.4*58.4mm; 53.3*53.3mm; 51*61mm – but frankly, I don't really know what that means, and I don't want to buy the two parts, realize they don't fit together, then have to return one or the other. Can anyone tell me how I can determine compatibility with these measurements? Thanks.
EDIT:
I just noticed the list of compatible cards ID-Cooling provides at the bottom of their page, so we're good! However, I'd still like to know how I can determine compatibility myself without the manufacturer explicitly telling me.
They have a compatability list on the web page you linked....
GPU COMPATIBILITY LIST (According to Mounting Holes)
51*61mm
NVIDIA
GeForce GTX 560Ti, 560SE, 560, 550Ti, 460SE, 460
53.3*53.3mm
NVIDIA
GeForce GTS 450, 250
AMD
Radeon R9 290X, 290, 285, 280X, 280, 270X, 270
Radeon R7 265
HD 7870 Series, 7850, 6970, 6950, 6870, 6850, 6790
HD 5870, 5850, 5830, 4890, 4870, 4850, 4830, 3870, 3850, 3690
58.4*58.4mm
NVIDIA
GeForce GTX 980Ti, 980, 970, 960, Titan Series
GeForce GTX 780Ti, 780, 760Ti, 760
GeForce GTX 680Ti, 680, 670, 660Ti, 660, 650Ti, 650
GeForce GTX 580, 570, 480, 470
To be honest, the 960 is a very cool and quiet running card anyway, I would only consider this worth while if you were using a very hot and loud card like the R9 290/290x.
Thanks for your feedback. Check out the update to my OP - I'm still hoping to learn how to understand those measurements and determine compatibility manually.
Not sure exactly what you are asking?
They are listing the compatibility based on the location of the mounting holes on the graphics card. Most card manufacturers wouldn't list these as its not information most people would need, so you do need to rely on their info unless you can find it from elsewhere.
