GPU With No External Power
police101
31
So I've been searching around on Google (there you go, I searched. So no critisizing saying I didn't try first!) and I have not found a solid answer and am getting mixed feelings. To set the record straight I figured I would seek advice.
I have a 220w power supply. Just buy reading that you may know that a graphics card is almost impossible to add to my computer. I thought about investing in a new power supply, but there is no professional ones available. I do have the option to buy a custom made power supply that is specifically built for my computer but I don't know if I want to risk my computer trying that. After some searching, I found that obviously some GPUs do not require an external power source and get power from the motherboard. My question is if I was to buy a graphics card, for example a GTX 750ti, would it be OK on my computer because the graphics card has no external power cord and my power supply is 220? Or would I still need a bigger power supply even though the card gets power through the motherboard? And would it be safe considering the minimum specs say 300w minimum or would I need to find a smaller card?
Thank you to anyone whom helps me with this question!
GPUs that use less than 75W can be entirely powered by the motherboard. EVGA appears to be making at least two 750Ti models without PCIe power connectors: their plain 750Ti and their 750Ti SC. Pictures of the PCB show an unpopulated footprint where the only PCIe power connector should have been.
Graphic cards don't get their power from the motherboard. You need to connect a PCI-E connector from the power supply and connect it to your graphics card to give it power.
Latest posts
