GPU Wont power up, even though it's connected to Power Supply
MiloSx7
104
Ok i bought 8x pin - molex 6 months ago but i needed 6 pins (which i had on my old PSU that died) and i cut both ends of molex cable i bought and 6pin cable on my PSU, and connected them and everything worked just fine until yesterday. I power up my PC, and its just beep-beeping with red flashing words on my screen saying that i should connect my GPU to power supply, which i already did.
GPU: Ati Radeon X1950 XT.
Should i just go and buy a new cable, or is it the problem with my graphic card?
Its not the MOBO, i tried the graphics card on my older and i get the exact same problem.
Thanks, cya
Actually i need molex to 6pin 😀 But, i will buy it, no probs!
Thanks! 😀
I will post here tonight when i come back from school and tell you weather it works or no.
Thanks again :)
Yes, its spinning, and starts working as it was before, but after the motherboard "beeps", it starts like "beep-beep-beep-beep" and showing some red words on black screen blinking :\
There isn't the limit to the beeps. It's an infinite loops. short beeps one after another, they appear every second i think. And they just go "beep, beep, beep..."
The message is written in red, and its blinking too, saying:
"YOU HAVE NOT CONNECTED THE POWER CABLE TO YOUR VIDEO CARD. PLEASE REFER TO THE 'GETTING STARTED GUIDE' FOR PROPER HARDWARE INSTALLATION"
This message appears before the "Bios screen" so i don't think i can enter Bios... Any ideas?
