Full specs:
FX-8350 with Cooler Master Hyper 212 EVO cooling
Radeon HD 7990
M5A99X EVO R2.0
24Gb of Ram
Corsair 800w PSU
Windows 7 Ultimate
I don't believe there is any major bottleneck with this system that should be causing such bad performance in games and stress tests. I am also not touching the clocks at all, I still get the same problems when leaving everything on its default setting.
I'm having multiple problems, the biggest of which is that my GPU won't stay at a consistent load. It keeps jumping all around even when the temps are low. Also, when I play GTA V (with CCC 15.4.1 Beta) or try to do a stress test my computer only utilizes one GPU, leaving the other one at 0%. In GTAV it doesn't even fully utilize the first GPU, only running it at about 80%, in the stress test it stayed at 100% most of the time. When I play Fallout 4 (with crossfire disabled because it does not support crossfire) the one GPU is constantly changing between 75-100% usage which causes a lot of micro-stuttering and random FPS drops.
So what I am asking is how do I keep my GPU running at a consistent load? Even if I have to underclock it that would be better than constantly changing load because that causes random FPS drops and micro-stuttering. It would be nice if I could use it at 100% though, otherwise it is kind of pointless having such a powerful card if I have to underclock it just to make it work and I might as well just sell it and buy something else. I'm not sure what is going wrong here because I know that GTAV supports crossfire with the 15.4.1 Update, and that even when I disable one of the GPUs intentionally to play Fallout 4, I still get performance issues and it runs very choppy because of the constantly changing load. So something is not right here because no matter what I am doing it seems that my GPU will not work at full capacity.
Also something else I noticed is that my CPU almost never goes about 80% usage as well.
Any help is greatly appreciated!
Radeon HD 7990
M5A99X EVO R2.0
24Gb of Ram
Corsair 800w PSU
Windows 7 Ultimate
