J juve97 Reputable Dec 21, 2014 9 0 4,510 Dec 22, 2014 #1 As the above states, i have opened my case to check the fan only to find that the fan does not spin. I reach roughly 99C and the computer will turn off during gameplay.
Solution I I i7Baby Dec 22, 2014 Make sure the pcie slot is clean. And that the power supply connector is on 100%. Check the fan spins by hand. Check the fan connector is on the card pcb connector 100%. Try another card. If it works OK, RMA the 260X.
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Dec 22, 2014 Solution #2 Make sure the pcie slot is clean. And that the power supply connector is on 100%. Check the fan spins by hand. Check the fan connector is on the card pcb connector 100%. Try another card. If it works OK, RMA the 260X. Upvote 0 Downvote Solution
