Graphic Card and Power supply problem ....
naughty_72
8
Hello,I want to upgrade my PC:
Motherboard:Asus P5B E Plus
CPU : Intel Core 2 Duo E6420 2.13Ghz
GPU:Ati Radeon X1300 256MB (to upgrade)
2GB Ram
Power Supply : No name ATX 450W P4
specz:230V-50Hz +3.3V(25A) +5V(36A) +12V (16A) -12V(0.5A) +5VSB(2.5A)
I want to upgrade Gpu to EVGA Geforce GT430 so problem is that card need minimum 300W (i have 450 and it is good) and need minimum 12V current rating of 22A ...as i understand i have 16A??Is it enough for my GT430 which i want to buy ??? Plz Help
naughty_72
8
how about that psu http://www.newegg.com/Product/Product.aspx?Item=N82E16817371045??? robjordy i think you are right about of HD6670 but it has PCI E 2.1 so mine need 2.0 because my motherboard ahve PCI E X16 slot .
That is a very good power supply unit.
HD 7750 would be the best upgrade for you - it's fastest among them all.
Also, PCIe versions are backwards compatible, that means that 2.1 or 3.0 card will work in 2.0 slot.
naughty_72
8
ok sunius i correct http://www.asus.com/Motherboards/Intel_Socket_775/P5BE_Plus/
1 x PCIe x16
1 x PCIe x4
1 x PCIe x1
3 x PCI 2.2
naughty_72
8
max for gpu is 70$ and for psu 40$ .I dont need mega card i need card for games like GTA4 ,COD MW4, BF3,Killing floor 2 and etc i dont want to run them on high setting
naughty_72
8
naughty_72
8
mohit9206 HD Radeons is good but i dont want buy them because if i buy i must change my mobo.So about link of antec Psu, Sunius iti is good?
