A Alantom Reputable Apr 4, 2014 8 0 4,520 Apr 4, 2014 #1 will an amd r7 250 1gb ddr5 graphics card be compatible with an asus p5g41tmlx3 motherboard ?
Solution cin19 Apr 4, 2014 The MB has the g41 chipset, even the pciex16 is the 1.1 version, it will work with pcie3.0X16 GPU, like this http://www.tomshardware.com/answers/id-1723833/moterboard-compatibility-issues-sapphire-radeon-7750-1gb-gddr5.html If the GPU don't work, then update the BIOS.
cin19 Titan Mar 14, 2011 15,722 218 112,340 Apr 4, 2014 Solution #2 The MB has the g41 chipset, even the pciex16 is the 1.1 version, it will work with pcie3.0X16 GPU, like this http://www.tomshardware.com/answers/id-1723833/moterboard-compatibility-issues-sapphire-radeon-7750-1gb-gddr5.html If the GPU don't work, then update the BIOS. Upvote 0 Downvote Solution
