I have a Zotac GTX 1070 AMP Edition graphics card and recently the fans just stopped spinning, they also dont even spin when starting up. The card works fine, i'm still able to change the rgb on it etc.if i attempt to game the temps shoot up to around 90c but again, the fans dont spin.I've tried manually setting the fan speed using Firestorm and MSI Afterburner but nothing works. HWmonitor shows the fan rpm at 0% constantly and when i go and physically check the card the fans arent spinning, but the "Fans PWM" reads at the speed i manually set the fans to run at. I've also tried replacing the fans, mind you from a ASUS GTX 1060 i had laying around but even that didnt work. Not sure what the problem is.
CPU: I5 3570K
GPU: Zotac GTX 1070 AMP
HDD: Seagate 1tb HDD @7200rpm
RAM: 16gb HyperX
PSU: Thermaltake TR2 700W 80+ Bronze
CPU: I5 3570K
RAM: 16gb HyperX
