Graphic card help
Wither12
13
So I have my PC build all I need it good graphic card.
I want to play games like BF4 on ultra/highest with good fps rate 40+ fps.
I want to spend around £250 any suggestions?
I have 1 monitor but Im thinking to buy second one with 1920x1080 and play on the new one.
I would recommend an R9 280X for your price range. It's a solid card with mature drivers, and when Mantle is implemented into BF4, it could perform even better. You should easily be able to max BF4 at 1080p with 40+ fps.
Zalman z11 plus
Asrock z77 extream 4
750w
i5-2310 (i will upgrade it)
4gb ram (I wi;; upgrade it to 12+)
corsair h55
gt 530
64-bit
windows 7
Also I was looking at those GPU's
2GB MSI GTX 760 Twin Frozr Gaming OC
2GB EVGA GTX 760 ACX,
2GB Asus GTX 760 DirectCU II OC
Up to £250 it can be bellow £250 as well
I was looking at Gigabyte gtx 760 4gb oc or evga gtx 760 4gb oc
or those GPU's
Wow that is quite a monster. You'll need more than 1GB of RAM just to run Windows these days. And the 4 year old 250W power supply isn't going to be enough for a dedicated GPU. Honestly, you'd get more for your money if you didn't upgrade it. Haven't you got another system?
