Graphic Card help
Glayne32
Hi there I’m new here I need help get a new HD graphic card the current graphic card that I have got now is the ATL Radeon HD4250. So I am looking to play the latest highly graphic games at max or mid settings
Here’s my budget for the GPU: £200 but I rather not spend that amount on GPU so the cheaper the better 😉
Here is my PC System
Operation System: Windows 7 Home Premium 32 bit (plan to update this at some point and before you ask, yes my machine will support 64 bit Windows as that was running on it before. Please don’t ask me what happen to it, it’s a very long story and that’s not what I am here for)
Screen resolution 1600 to 900 (I just put this in because I have hear the higher the resolution is the more powerful GPU needs to be)
CPU: AMD Athlon II X3
Motherboard: MB.SE109.002 / MBSE109002
I have a Acer m3400 if this help you if there’s any other info you require please let me know, thank you
